carb swap
Old Feb 14, 2012 | 03:24 PM
firebirdfreak87's Avatar
Car: 87 firebird did V8 swap
Engine: sbc 350
Transmission: 700r4 shift kit and stall
carb swap
ok im doing a tpi to carb swap what can i keep what wires do i need to keep and what ones can i get ridof what do i need to do in order to make lights and gauges still work mainly speedometer and
Old Feb 14, 2012 | 06:31 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
In the "welcome to the carburetor forum" sticky in the top section of this forum, there is a link to a tech article on converting from EFI to carb.
It has also been discussed numerous times, such that a search would tell you that the ECM harness that goes to the passenger side fenderwell can all be removed intact without cutting anything, and that the wires that remain from the connectors on the driver side of the firewall will provide power to starter, alternator, ignition, and gauges when you do this downgrade.
For the record, unless you have an '87-older f-body, and unless you do a computer carb, this conversion is illegal for street use in all 50 of the United States. Just for the record...
Old Feb 17, 2012 | 11:08 PM
rusty vango's Avatar
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
Re: carb swap
ever wonder why some dudes remove everything they dont comprehend? its amazing at the amount of posters asking the "can i take it off" question
Old Feb 22, 2012 | 08:45 AM
Engine: sbc 350
Re: carb swap
i was just askin cause im not good with this FI stuff now carb i can do its the whole computer crap i cant do im only 17 i wanna learn all of it but just so complicted and i dont need this post anymore actually its wired up and running
Old Feb 24, 2012 | 07:40 PM
Brando5641's Avatar
Car: 1998 Trans/Am, 1989 RS Camaro
Engine: LS1, LQ9 6.0
Transmission: 4L60E, 4L60E
Axle/Gears: 2.73, 2.73
Re: carb swap
lol go ez on him... I remember when i was that age on a forum. If i only knew then what i know now....
midge54
Dec 27, 2019 04:14 PM
theshackle
Mar 5, 2017 06:37 PM
midge54
Jan 29, 2017 07:00 PM
theurge
Aug 21, 2015 12:46 PM
cstrobel65
Aug 15, 2015 10:19 AM
