cfi to carb
Car: 82 Z28 Indy Pace car
Engine: 383
Axle/Gears: 4:10
cfi to carb
I swapped the stock 305 and CFI in my 82Z for a carburated 350. I was hopeing to leave the stock fuel pump in the tank and put an in-line fuel pressure regulator before the carb. How do I go about re-routing the return line so as not to burn out the pump?
Transmission: 4L80E/4L80E
Welcome aboard thirdgen.org.
Basically hook up the regulator return port to the return line in the car. What kind of information did you need beyond that?
RedLeader289
May 28, 2019 01:47 PM
efiguy
Sep 27, 2015 01:30 PM
