Will this Air Filter fit??
Old Apr 6, 2012 | 10:39 PM
calgutie's Avatar
Car: 1984 Z28
Engine: 5.0 L (Carbed)
Transmission: 5-Speed
Axle/Gears: Lazy 2 check
I got a 84 z28 carbed engine (manual transmission), and I wanted to know if this would fit in my car?? and if not is there something similar out there hat would fit?? and not too pricy either thanks!!
Also if there is any alternatives, I am kinda leading towards stainless steel look, and also what difference (performance) will this make besides my stock one, if any? thanks soo much!
calgutie's Avatar
Car: 1984 Z28
Re: Will this Air Filter fit??
oops and here is the link
http://www.jegs.com/i/Edelbrock/350/1221/10002/-1
Old Apr 6, 2012 | 10:47 PM
SDTransAM's Avatar
Car: '83 z/28
Axle/Gears: Stock?
Yes, I have the same one on my '83. Didn't you already start a thread about air filters?
It was quite a big difference on my '83 I noticed quite a bit of power increase. Well as much as this little 305 will put out.
Old Apr 6, 2012 | 10:49 PM
calgutie's Avatar
Car: 1984 Z28
ajja yes I did...Im just lost in my car and I got problems all over...but as long as it runs....
bu do you reccomend anything else for the price?
and is this fairly easy to install, and where would my PCV valves go?thanks...
Old Apr 6, 2012 | 10:56 PM
SDTransAM's Avatar
Car: '83 z/28
Axle/Gears: Stock?
Yes, it's a direct fit, just rip out all of your old air filter stuff. Bolt this on and go. The passenger side valve cover doesn't use a PCV (mine doesnt anyways) it is just a breather tube. I went and got a chrome valve cover breather and stuck that in there.
Old Apr 6, 2012 | 11:04 PM
calgutie's Avatar
Car: 1984 Z28
cool,. thanks much appreciated!!
Old Apr 7, 2012 | 04:24 AM
Slow87's Avatar
Car: 87 Camaro Lt
Axle/Gears: 4th gen 3:42, posi, disc
I just got this same one today!
Is it really supposed to bolt on? My old airfilter housing wasn't bolted on. Also the vacuum hose that went into the bottom and then went to the snorkel, what do I do with it?
1992 Trans Am
May 10, 2023 07:19 PM
specialized
Jun 18, 2022 09:26 AM
Brinkkl2000
Aug 4, 2018 08:29 AM
theurge
Aug 21, 2015 12:46 PM
