may have problem with intake
Car: 88 Camaro
Engine: 5.0
Transmission: 700r4w/shift kit
Axle/Gears: 10 bolt
i am doing the tbi to carb swap and i bought the jegs brand intake i drilled out the four center holes but it still doesnt seam to line up right part of the intake is hitting the top of the head where the valve covers bolt on and leaves a gap on one side in between the gasket and intake and i also seen where it doesnt have a coolant passage on the back of the intake by the dizzy it is just blocked off no holes or anything shouldnt there be a coolant passage like on the tbi intake
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: may have problem with intake
No coolant passages in the back is normal.
Can you post some pictures of your alignment problems?
Car: 88 Camaro
Engine: 5.0
Axle/Gears: 10 bolt
so the back coolant ports can be blocked off and it will be ok
ill try and get some pics on here tom. if i came figure out how to
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Try photobucket.com to host your photos/
Did you get a pre 87 intake or a post 87? What part number?
Car: 88 Camaro
Engine: 5.0
Axle/Gears: 10 bolt
i got the pre 87 intake dont know the part # but its the jegs brand
