Do I need a wideband 02 sensor or will narrowband do?
Car: 88 Camaro
Engine: 416 Stroker LS
Transmission: Magnum F
Axle/Gears: 4.11
I want to install an o2 sensor so I can turn my carb properly. Do I have to have a wide band for this or will a narrow do?
If it has to be wide, what's a good one to go with? I only want it for carb tuning, not for dynos or data logging or anything like that.
Car: 1988 Camaro
Engine: 377
Transmission: TH350; Circle D 4200 converter
Axle/Gears: Ford 9"
Re: Do I need a wideband 02 sensor or will narrowband do?
The AEM Widebands are nice. Don't bother with a narrowband.
Car: 92 rs daily driver work in progress
Engine: 3.1 , 204/214 cam
Transmission: 700 r-4, b& m megashifter
Axle/Gears: I want a posi with rear discs
Does bosch make a wideband? I changed a/f gauges and the new one needs a wideband, the old one was a narrow band.
Also they are direct bolt-ins right? No other mods need to be done
HoosierinWA
Oct 7, 2015 10:15 AM
efiguy
Sep 27, 2015 01:30 PM
89, band, camaro, carburated, carbureted, carburetor, narrow, narrowband, o2, oxygen, sensor, supercharger, tuning, turning, wide, wideband
