quick question
Old May 22, 2012 | 09:20 PM
spaigo's Avatar
quick question
This may sound dumb, but there r 2 cables that run to my carb. I know one of the cables is for throttle, but what is the other one for?
Old May 22, 2012 | 09:34 PM
Re: quick question
Either cruise control, or the TV cable to the trans.
Old May 22, 2012 | 09:37 PM
spaigo's Avatar
Re: quick question
just fig it out, its the transminson kick down cable. I have another question then. There is alot of slack to the cable should I find a way to make it tighter or leave it lose?
Old May 23, 2012 | 07:22 AM
Re: quick question
Depends on what transmission you have.
Since you're calling it a "kickdown cable", that must mean you have an automatic?
However, unless you have an older pre-3rd-gen transmission transplanted into the car such as a Turbo 350, it's not a "kickdown cable"; it's a "TV cable", as mentioned previously. (Throttle Valve)
www.tvmadeez.com
Read the "TV 101 Article". Completely, from start to finish, comparing each part you see including the ones inside the trans, to the ones in your car. Come back if you have any further questions.
Old May 23, 2012 | 11:15 AM
spaigo's Avatar
Re: quick question
Thanks for help that article was just what u need to fix my problem
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
jahblah
Aug 12, 2015 05:54 PM
