Edelbrock 1405
Old Jul 4, 2012 | 02:25 PM
onthedownlow's Avatar
Car: 1984 Camaro Berlinetta
Engine: 355
Axle/Gears: Australian 9 bolt 3.27 posi
Edelbrock 1405
I have an edelbrock 1405 carb on my 355. I also added an electric choke. The idle is pretty good but when I am driving, say third gear and am just holding the gas at a steady, the car jerks violently. If I am on the throttle it runs fine, the moment I try to keep a consistent speed it goes into jerk mode. I should mention that I just installed a msd 6al and ended up messing with the mixture screws on the front of the carb while trying to get the optimal mixture. So I need to know what would be my next best move to get her back to running properly. Oh also there is an occasional backfire wile in the lower rpms. Thanks
on the dl
Old Jul 4, 2012 | 07:35 PM
Mac10's Avatar
Re: Edelbrock 1405
I think i have the same carb . sounds like your too lean for the idle mixture . I think the way to fix that was get the car warm , turn the idle screws to pretty much a close . then turn them each a little richer and you will notice the idle speed picks up . you make it rich untill the idle speed no longer speeds up , then you adjust the idle . if that doesnt work try swearing
Old Jul 4, 2012 | 09:32 PM
Engine: 355
Re: Edelbrock 1405
Right on Mac, I will try it as you describe. Many thanks.
on the dl
Pac J
May 17, 2020 10:44 AM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
skinny z
Carburetors
Sep 29, 2015 11:25 PM
efiguy
Sep 27, 2015 01:30 PM
Night rider327
Sep 25, 2015 04:47 AM
