CARB HELP!!!
Old Jul 9, 2012 | 08:41 PM
Fiero_Man_87's Avatar
Want a title? Post!
CARB HELP!!!
I just got a 83 Trans am and it wont turn over, its not the fuel pump i know that its something to do with the CARB. I can hear the gas being shot into the carb but its just not getting to the engine to ignite, it gets right to the point to where it will almost turn over as long as your spraying carb cleaner on it, this is my first car and i dont know the carbs that well is this a expensive repair or a cheap one? HELP I NEED AN ANSWER ASAP
Old Jul 10, 2012 | 06:49 AM
pancherj's Avatar
Car: 1990 IROC
Engine: Rebuilt L98 with H/C/I/Carb
Transmission: TH350 with ATI Treemaster
Axle/Gears: 7.5 with 4.10's
Re: CARB HELP!!!
Not the carb at all! Most likely a dead battery or bad battery cables (corrosion or rust). If those check out okay, move onto the starter itself and the ignition.
Old Jul 10, 2012 | 07:21 AM
TreeFiddy's Avatar
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
Re: CARB HELP!!!
Agreed, start with the electrics esp the big cables. How fast is it cranking?
RedLeader289
May 28, 2019 01:47 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
IROC ZELLER
Sep 29, 2015 03:00 PM
efiguy
Sep 27, 2015 01:30 PM
