Used Carb
Car: 1985 CAMARO
Engine: 350 v8 CARB
Used Carb
My car came with a holley double pumper carb. im not even sure which model it is because i cant find a model id on it. But my question is, is there a way to test a carb to see if it works? where is the model id located? and whats the corect way to clean it?
Car: 1991 Camaro Z28
Axle/Gears: Strange 12 Bolt, 3.42
Re: Used Carb
The holley part# should be stamped somewhere on the carb, it normally starts with an R and has 4 or 5 numbers after it. I would take everything apart and clean it with carb cleaner. If it looks good I would put it back together and try it. If it looks dirty, or you have some parts that look questionable get a rebuild kit for it. Once you get the model# figured out you may want to look at this chart from the holley website.
http://holley.com/data/TechService/T...%20Listing.pdf
The chart shows the stock jet sizes etc, and rebuild kit part#'s. You probably want to return it to the stock settings before putting it on your car, it may have been tuned for whatever engine it came off of and not work correctly on yours. The stock settings are always a good place to start.
Car: 1985 CAMARO
Engine: 350 v8 CARB
Re: Used Carb
ok. from what i have read. the carb i have is a 650cfm double pumper. I took it apart and it was really clean in the inside and had new gaskets in it. hopefully it works
Transmission: 4L80E/4L80E
RedLeader289
May 28, 2019 01:47 PM
efiguy
Sep 27, 2015 01:30 PM
