Edelbrock 1406 help
Old Oct 17, 2012 | 12:29 PM
blue birdy 87's Avatar
Car: White 84 z28
Engine: Chevy 350
Axle/Gears: Posi and?
Edelbrock 1406 help
Two questions what does the cable in the picture do? Is that my choke cable? I have ran the car with it on and off (because it fell off) and I cannot tell what it does.
Those two front ***** adjust fuel air mix, what way do I turn them to lean it out? And how much should I try turning them?
Attached Thumbnails Edelbrock 1406 help-101_1932.jpg   Edelbrock 1406 help-101_1933.jpg
Old Oct 17, 2012 | 12:37 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Edelbrock 1406 help
The cable with the slotted end is the cruise control cable.
The two front ***** only adjust the idle mixture. Before making any adjustments, read the Edelbrock manual completely from front to back before doing anything, and then follow every single one of their tuning steps exactly, and in the order listed. It would be hard to find a better description of the tuning process than the one they include in the manual. A .pdf is available on the Edelbrock website if you don't have the paper manual.
Old Oct 17, 2012 | 05:19 PM
THETANK's Avatar
Car: 91 rs
Engine: Carbed 355 CR 9:1 xr276 cam
Transmission: 700r4 2600 stall
Check these videos out they pretty much cover everything.
http://www.edelbrock.com/automotive_...ech_vids.shtml
Old Oct 17, 2012 | 08:29 PM
Car: White 84 z28
Engine: Chevy 350
Ok so ive read more and watched several videos. I just adjusted my idle mixture and fast idle level. I bought it used and did not come with new metering rods or jets. I guess I need to buy some slightly smaller ones for my car. I always thought there was a dial to change the fuel ratio above but I guess not
Pac J
May 17, 2020 10:44 AM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
skinny z
Carburetors
Sep 29, 2015 11:25 PM
efiguy
Sep 27, 2015 01:30 PM
Night rider327
Sep 25, 2015 04:47 AM
