Carb + RTV = No No
Old Oct 25, 2012 | 11:12 AM
bestracing's Avatar
Car: 86 T/A - 70 Z28/RS
Engine: Broke - 350
Transmission: 700R4 - M22
Axle/Gears: G80, 2.73 - ZQ9 G80 4.10
Carb + RTV = No No
I'm rebuilding a Holley 1850 (600cfm) carb for a friend. Evidently they guy that use to own the truck that this came off of decided to add a little Ultra Blue RTV to the bowl and metering block gaskets before bolting it together. It was a very thin layer but still some of it oozed out to the passages partially blocking them. It's no wonder why they were having problems with this carb.
Just a word of warning, do yourself a favor and get the right gaskets first before you open anything up and don't try to use RTV as an added sealing measure. You might just seal something up that wasn't meant to be sealed.
Old Oct 25, 2012 | 11:24 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Carb + RTV = No No
Seen that more than once.
Old Oct 25, 2012 | 10:26 PM
Damon's Avatar
Agreed. They go together DRY, just gaskets.
Applies to all makes and models of carbs I've ever worked on.
Old Oct 26, 2012 | 08:06 PM
First car I ever bought, first time I rebuilt the carb (basically the 1st weekend I owned it), I made that mistake.
Never again.
Fortunately lacquer thinner softens it up even more than gasoline does, and gets it right out of everything.
You can use silicone spray lube on gaskets to help em not stick; maybe a SUPER THIN coating of grease. Definitely NO SEALER though.
Old Oct 29, 2012 | 11:31 AM
bestracing's Avatar
Engine: Broke - 350
I just buy the non-stick gaskets (Holley) and that works great for me.
RedLeader289
May 28, 2019 01:47 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
IROC ZELLER
Sep 29, 2015 03:00 PM
efiguy
Sep 27, 2015 01:30 PM
