Need help!
Old Oct 28, 2012 | 03:54 AM
Slow87's Avatar
Car: 87 Camaro Lt
Axle/Gears: 4th gen 3:42, posi, disc
Need help!
87 camaro lg4, r700
So I decided to install my headers, which inspired me to remove my smog and A.i.r. stuff. ( I don't care about emissions). The car is a weekend driver, and I'm looking to heavily modify it.
Question 1. What vacuum hoses are required to run my cc q-jet?
Question 2. I have a vacuum controlled HEI distributor that I want to install, do I have to wait till I have a non computer controlled carb or can I just install it?
I did a search on this stuff but every topic just ended in a stupid emissions debate on if it's its worth it to remove.
Old Nov 3, 2012 | 04:17 PM
danryanm's Avatar
Car: '86 Trans Amvanian Frankenbird
Engine: 350 4bbl
Transmission: T5 4.03/.76
I'm in the same boat with you. I've built a 350 to replace my anti-theft device (non-running 305) and I was hoping to retain the Quadrajet (I even bought a spreadbore intake for the Vortec heads) but it is an electric '86 model. I'm going to use an Accel mechanical/vacuum distributor, but I really don't want to use an aftermarket carburetor if I can avoid it.
Old Nov 6, 2012 | 06:04 PM
ChrisC's Avatar
Car: 1983 Z28/2000 ZR2
Engine: CFI to carbed 305/ 4.3
Transmission: Built 700r4/4L60e
Axle/Gears: 3:23/3:73
Re: Need help!
Slow87, there's nothing wrong with the cc qjet and distributor. In fact, the q jet is the best carb for your application. Installing a new distributor and carburetor will likely show no difference, everything else remaining the same and assuming nothing is wrong with your current carburetor. Everyone is too quick to rid the quadrajet but it produces equal or more power and gas mileage to an aftermarket. What are your heavy mod plans?
Old Nov 7, 2012 | 04:25 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
The line/hose to the manifold vacuum sensor, power brake booster, choke pull-off (aka, "vacuum break"), and if you have a snorkel air cleaner, the one to the thermovac servo. You can/should also retain the charcoal canister lines. If you retain EGR, that one.
Can only use it with a non-computer carb. If you use it with a computer carb, the carb will be in full rich mode all the time.
Old Nov 8, 2012 | 02:43 AM
Slow87's Avatar
Car: 87 Camaro Lt
Re: Need help!
Thank you five7kid!. For all the sensors that are just dangling off the wiring harness, what do I do with those? Do most people tuck them some how or just cut them off?
Old Nov 8, 2012 | 01:21 PM
five7kid's Avatar
If you're talking about staying computer controlled, you leave them.
If you're talking about going all non-computer, you either remove the ECM harness as a whole, or coil & stow - don't cut anything.
Old Nov 8, 2012 | 01:47 PM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
Re: Need help!
Just tuck the pigtails for the AIR control back into the harness somewhere. Don't cut them.
I'd keep EGR. It will help reduce pinging at light throttle tip in from low speed cruise allowing you to run more base timing.
