Carb help
Car: 1987 Camaro LT
Engine: 305 4bbl
Carb help
I have an 87 lg4 original carb and i took my coolant temperature sensor to put a aftermarket gauge in. After about two weeks the idel shot up to 2500 rpm and wouldnt idel down. After messing with my idel screws anything below1500 it would kill. So i put the sensor back in and now it wont start on a cold start at all. I have to take the plug off the sensor to crank it. Any help????
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
re: Carb help
Where exactly, on your engine, is the sensor you replaced?
RedLeader289
May 28, 2019 01:47 PM
efiguy
Sep 27, 2015 01:30 PM
