TPI to Carb what carb ?
Old Dec 24, 2012 | 08:49 PM
shwinny's Avatar
I am putting a 383 Stroker in my 87 GTA that was 350 TPI. I did not pick out a carb yet but i need a 750cfm to feed this motor. Should i find a throttle cable from an 86 carburated car? What carb to run? Lock up/throttle bracket ETC. Was wondering what you guys thought. any info to get me in the right direction.
383 stroker
forged everything
canfield aluminum heads
edelbrock performer rpm intake
10:1 compresion
700r4 Probuit trans
Old Dec 25, 2012 | 12:56 PM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
Main thing is to get the tv cable adjusted correctly if that's with a mtg bracket, universal, or a system like tv made ez. That tv cable is used for line pressure.
If you plan on using the FI pump you will need a Mallory 4309 regulator (bypass style) to get it down to carb pressures.
If you are not using the oil safety switch you will need to replace it or wire the relay for the fuel pump to run. It will only run for 2 seconds otherwise.
Posted from Thirdgen.org App for Android
Old Dec 26, 2012 | 08:29 PM
pancherj's Avatar
Car: 1990 IROC
Engine: Rebuilt L98 with H/C/I/Carb
Transmission: TH350 with ATI Treemaster
Axle/Gears: 7.5 with 4.10's
Re: TPI to Carb what carb ?
Any camshaft details?
Old Dec 27, 2012 | 07:44 AM
shwinny's Avatar
*hydraulic roller*cam is a XFI 280 cam with spec of 230/236 Duration @ .050" and lift of
.570/.570 and a 113 LSA
Old Dec 27, 2012 | 07:50 AM
pancherj's Avatar
Car: 1990 IROC
A 750 double pumper would be my recommendation. I like AED and BG, but there are lots of good ones out there. The 750 Mighty Demon on my 350 runs real good, but it took some work to get there.
gta90
Sep 15, 2015 04:00 PM
beachrodder
Aug 25, 2015 08:05 AM
theurge
Aug 21, 2015 12:46 PM
86IROC112
Aug 17, 2015 02:00 PM
Sanjay
Aug 12, 2015 03:41 PM
