Making carb functional with the old cross fire cowl
Old Jan 11, 2013 | 10:33 PM
lilman0883's Avatar
Car: 1983 trans am
Axle/Gears: 4 wheel disc 3.23
On my cowl hood on my 1983 trans an it's set up for a crossfire, how can I make the cowl functional with my new 350 carb setup?
Old Jan 12, 2013 | 02:04 AM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Re: Making carb functional with the old cross fire cowl
Ive been contemplating this for a little while, actually. I think there are ways to do it, but the main concern is water getting into the engine. So you have to build some sort of plate off of the underside of the hood to direct water away from the carb inlet and then leave a larger airbox open with teh filter inside it. Then it gets weird because the last thing you want water on is the distributor... So you'd have to direct it to the sides and seal off the distributor area.
92camaroJoe
Jul 29, 2023 07:57 PM
theshackle
Mar 5, 2017 06:37 PM
Black89TA
Exterior Parts for Sale
Jul 23, 2016 10:42 AM
92camaroJoe
Aug 13, 2015 06:07 AM
mustangman65_79
Aug 11, 2015 03:17 PM
