Eletric Fuel Pump
Car: 74 Nova prostreet 87 Iroc Z28
Engine: 427 671 blower 350 Built
Transmission: 700R4 both
Axle/Gears: Dana 60 an a 323 posi.
Eletric Fuel Pump
I need some advice 87 z28 changed to carberator my question is can you leave the stock ele. pump in the tank an disconnect it an mount a different ele. carb. pump on the frame cut the lines from the stock pump and connect them to the new pump will it work . I know you can use a reg. an use the stock pump in tank. Thanks
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
Re: Eletric Fuel Pump
IMHO
If the stock pump is good, I would get the Mallory return regulator
Or
Drop the tank & remove the stock pump & plumb the aftermarket pump as you desire
Or
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
