Normal Idle speed
Old May 23, 2013 | 11:26 PM
djjon76's Avatar
Car: '84 Trans Am
Normal Idle speed
Hi all. Just a quick one. Whats a normal idol, in neutral, for an auto 84?
I'm guessing around 800-850 as it is meant to drop to 650 in drive.
Cheers.
Jonno.
Old May 24, 2013 | 02:13 AM
RocketyMan's Avatar
Car: '96 Camaro-Vsux -- SOLD, '84 Z/28
Engine: 3.8L, 305 SBC
Transmission: 4L60E, T-5
Axle/Gears: 3.08s, 3.23s
Re: Normal Idle speed
If your car still has the sticker on the hood, you should be able to read that manuals should idle around 700 RPMs and then autos should idle I think 650 in drive.
But going 800-850 RPMs down to 650 RPMs is quite the jump...
Old May 24, 2013 | 02:44 AM
djjon76's Avatar
Car: '84 Trans Am
Yeah. It has 650. But that's in drive. Im just curious what people think it should be in park.
Old May 24, 2013 | 03:20 AM
RocketyMan's Avatar
Look for the sticker on your hood. It should specify.
Old May 24, 2013 | 03:52 AM
djjon76's Avatar
Car: '84 Trans Am
It does. But only while it is in drive.
Old May 25, 2013 | 11:51 AM
camarito's Avatar
Car: 84 Z28 / 11 genesis coupe
Engine: 355/210 heads/275deh/Proform 750 DP
Transmission: 700r4/B&M 2400
Axle/Gears: 02, allu.axle, 3.42, posi
it depends on your air fuel ratio, vacuum and advance at idle and the ability of you setup to compensate for the TC load, mine idles at 900 in park and drops to 750 in drive with the combo I have, a little higher idle is better as you get better oiling and better off idle response
ezobens
Aug 19, 2015 10:29 PM
jbd1969
Aug 17, 2015 07:06 PM
perZ
Aug 15, 2015 01:17 PM
IROCThe5.7L
Aug 10, 2015 11:24 AM
