how much vacuum is too much vacuum?
Old Jul 29, 2013 | 02:11 PM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
I was going over my adjustments today and when I have a vacuum gauge hooked up to my pcv port on my carb, I'm pulling a steady 22-23 HGS of vacuum at 750 rpm on a v6 tach. Good? Bad? I tried setting my timing by vacuum but it didn't look to good lol.
Old Jul 29, 2013 | 02:51 PM
JaBoT's Avatar
Re: how much vacuum is too much vacuum?
That's fine. A stock cam is always going to have high vacuum at idle.
Why are you setting your timing according to vacuum? Thats not a good idea!
With that small camshaft it doesn't need a lot of timing down low. Just order the spring kit for an hei and put the light or medium springs in it and set timing at between 32 - 34 at 3500 rpm. Wherever it falls at idle doesn't really matter.
Old Jul 29, 2013 | 03:26 PM
manolis1969's Avatar
Car: klowny1969 <-youtube 4 3rd gen vids
Engine: subscribe to klowny1969 on youtube!
Transmission: subscribe to my channel on youtube
stock cam thats about right...HOWEVER...alot of people dont know that in the high performance world..if you have a very lumpy cam and ur vacuum is way too high..that could mean that either the lobes have been rounded out or something is binding or not working right in your valvetrain...so too much vacuum can also be a bad thing..it all depends..
Old Jul 29, 2013 | 05:18 PM
Engine: L31 350
yeah I stopped trying to time it by vacuum. It didn't feel right. I sat it for best idle and throttle response and set my air bleeds by vacuum
Old Jul 29, 2013 | 05:40 PM
JaBoT's Avatar
you shouldn't be setting idle timing for best idle either unless you can also properly adjust total timing also. Just set it around 12 - 14 at idle or do what I said in my last post.
Pac J
May 17, 2020 10:44 AM
FormulasOnly
Jul 23, 2018 08:47 AM
HoosierinWA
Oct 7, 2015 10:15 AM
timonator
Sep 30, 2015 12:52 PM
dusterbd
Sep 29, 2015 08:40 AM
