cc carb swap
Old Aug 31, 2013 | 09:57 AM
rockett3s's Avatar
Car: 83 Z28, 84 Z28
Engine: 305 crossfire, 350 carberator
Transmission: 700r4, t56
Axle/Gears: 10 bolt 3.42, 9 bolt 3.73
cc carb swap
I want to swap from the cc carb to a standard carb, what else do i need to change. thank you for any input.
Old Sep 1, 2013 | 08:26 AM
jwfirebird's Avatar
Car: 87 bird
Engine: enough to break stuff
Transmission: manual th400
Axle/Gears: 4.10
Re: cc carb swap
if you are just driving it on the street it is likely better to fix your qjet. what are you going to be doing with it and what engine/trans/year? i personally would rather have a holley but you spend alot of money and time getting it right for only minimal racing performance gain. i have done it but i was only racing my car at the time
Old Sep 7, 2013 | 11:32 PM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Re: cc carb swap
Why do you want to switch from the CC carb? It will run much better and get better economy as well as just as much power as a "standard" carb and will be cheaper to rebuild or fix than buying all the parts needed to do a swap over.
Old Sep 15, 2013 | 06:36 PM
rockett3s's Avatar
Car: 83 Z28, 84 Z28
Re: cc carb swap
My daughter just recently bought the car. Its an 84 Z28 with a 5 speed and a warm over 350. On the trip home it was running rich and backfiring through the exhaust. We are currently in the middle of a transmission upgrade, 2nd an 4th were non functional in the T5. It will be a daily driver for her.
Old Sep 16, 2013 | 09:49 AM
MD83Z's Avatar
Re: cc carb swap
Just need a non-computer Q-jet and vacuum distributor.....Now you can play with the springs and weights and vac can to adjust timing.
midge54
Dec 27, 2019 04:14 PM
theshackle
Mar 5, 2017 06:37 PM
midge54
Jan 29, 2017 07:00 PM
theurge
Aug 21, 2015 12:46 PM
cstrobel65
Aug 15, 2015 10:19 AM
