Type of Fuel
Old Sep 11, 2013 | 03:55 PM
muggymatt88's Avatar
Car: 89 Camaro Iroc
Type of Fuel
I was wondering will running higher octane help with cold starting or would it have no effect. Also on a Edelbrock carb with manual choke how far should the choke close. Thanks
Old Sep 11, 2013 | 05:51 PM
Re: Type of Fuel
No effect whatsoever. Only thing it will accomplish in most cases is weight reduction, concentrated at the driver's wallet. It's mostly a marketing gimmick.
However far you pull the cable.
Old Sep 11, 2013 | 06:50 PM
camaroracer21's Avatar
Car: 1983 Camaro
Engine: 358 SBC
Transmission: TH350
Axle/Gears: 9" Ford 4.56s
Re: Type of Fuel
sofakingdom is exactly right. the higher the octane the bigger dent in the wallet. I run Sonoco purple 110 octane in my racecar. At around 9.50 a gallon, it puts a hurting on the wallet but then again what in drag racing does not. As for your carb, the octane level of fuel will not improve the cold start. Stick to regular
Frozer!!!
Jan 19, 2024 04:55 PM
colton_carlson
Mar 8, 2019 12:21 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
dyeager535
Aug 28, 2015 08:10 AM
92camaroJoe
Aug 13, 2015 06:07 AM
