84 T/A w/In-tank pusher pump--the relay...where is it?
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Also posted in the Tech/General thread...
I've got an 84 that had the in-tank pusher pump added to it. I replaced my in-tank pump some years back with a 255lph wahlboro unit but ran an external fuel pump relay to power it because I couldn't get power to the power pin on the factory connector. I'd like to use the factory harness but I have no idea where the relay in the engine bay is (Assuming the wiring is good here). I do know that there was no fuse in the fuse box at the time I did the change over so the pusher-pump wasn't operational. I did put a fuse in to try and get power. It didn't. So more than likely the relay or the wiring is bad...I'd like to start with the relay.
Does anyone have a picture or good description of where the relay would be? on a carbed car with the pusher pump? Any help would be greatly appreciated!
2012sergen11
Oct 13, 2015 07:38 PM
