LU5 from CFI to Carb
Old Oct 10, 2013 | 01:16 PM
katrav8's Avatar
Car: 1982 trans am
Engine: 4bbl carb 305 v8
Transmission: 3 auto
I bought a trans am 1982 with an LU5 305 V8 which used to be CFI.
The previous owner changed CFI to carb using a 4BBL carb.
Now the carb has the code 17057204AYN.
How can i find how many CFM it is and if it is suitable for my engine.
If it is not suitable what is the right cfm it must have
Old Oct 10, 2013 | 01:58 PM
jwfirebird's Avatar
Car: 87 bird
Engine: enough to break stuff
Transmission: manual th400
Axle/Gears: 4.10
Re: LU5 from CFI to Carb
decodes to 1977, regular emissions, chevy with an auto. most of those are the same about 750cfm whether they were on a 305, 350 whatever. the only special ones were on the bigger and performance engines. so to answer your question it is likely a good carb to have on your engine.
http://www.cliffshighperformance.com...carb_ID_2.html
RedLeader289
May 28, 2019 01:47 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
IROC ZELLER
Sep 29, 2015 03:00 PM
efiguy
Sep 27, 2015 01:30 PM
