Need Some Advice Please Help !
Old Dec 18, 2013 | 03:45 PM
789roby789's Avatar
Car: 1986 Camaro Sport Coupe
Transmission: 700-R4
hey i have a 350 with a rochester qjet i recently puerchased an edelbrock performer 1400 series and i want to replace my intake manifold so my question is what intake manifold will bolt on with my stock heads? what have you guys done?? i dont care if the intake manifold is cali legal for emissions or not . i would appreciate any feed back thanks!
Old Dec 19, 2013 | 02:42 PM
WASyL's Avatar
Car: 1988 Pontiac Firebird
Engine: 305 LT1 intake&heads
Transmission: TH700r4
Axle/Gears: 3.73 10bolt GM
Re: Need Some Advice Please Help !
i do have Weiand SpeedWarrior and it works quite well
best regards
Old Dec 19, 2013 | 07:40 PM
Damon's Avatar
Summit sells a line of house-brand intake manifolds that are re-badged Weiand intakes with a few bucks knocked off the price.
Your Edelbrock 1405/1406/1407 will bolt onto practically ANY aftermarket intake manifold. Technically, it's a "squarebore" carb, like most Holleys, but it has enough "width" to the baseplate it will cover the carb flange on a "spreadbore carb" intake manifold with absolutely no problem (no vacuum leaks, everything works exactly like it should).
Personally, I prefer "spreadbore" intake manifolds. You can put a QJet on them, or an Edelbrock, or even a Holley squarebore carb (with a $6 adapter plate, also available from Summit). Gives you more options in the future.
HoosierinWA
Oct 7, 2015 10:15 AM
jaridjohn
Oct 5, 2015 07:01 AM
gord327
Sep 29, 2015 10:18 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
mrdevontay
Sep 2, 2015 08:04 PM
