151 conversion to carb.
I have a 1984 151 engine with fuel injection... the wiring, the pump , the injector is all messed up , so I am planing to do a CARB SWAP. the question is can I put the stock distributor and coil and rewire it to use it on a carb? What do I need to make it happen?
The problem is the availability of parts, I plan on putting a dual WEBBER carb , electric low pressure fuel pump , but the HEI distributor for a 2.5 costs WAAAAAY to much in Croatia...
here are pics of the distributor , so if anyone has some info on wiring that distributor, would be great.
Engine: 350sbc
Transmission: TH700R4
Re: 151 conversion to carb.
No you will not b able to run that distributor with out the ecu.
You could probley find some one that could send you one out there cheaper then a new one.
RedLeader289
May 28, 2019 01:47 PM
