carb swap help
Old Mar 15, 2014 | 04:26 PM
goinbrokeracin's Avatar
carb swap help
ok.. i have a 87 firebird with a 350 in it. i want to get a new carb for it, as the existing one is old, worn out, and gives me terrible throttle response. I dont have the time or skill to rebuild it myself, and want a quick easy swap/fix. from what i can guess, the existing carb is a Computer Command Control E4ME Quadrajet.. question is: can i go to a Street Demon, 625 cfm, 4-Barrel, Square Bore/Spread Bore, Electric Choke? it seems to me the hookups will all be the same, except for that Idle Mixture Control Solenoid plug on top front?
Attached Thumbnails carb swap help-image-1-.jpeg   carb swap help-image-2-.jpeg
Old Mar 15, 2014 | 07:03 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: carb swap help
Not if you want a quick/easy fix.
Old Mar 15, 2014 | 07:31 PM
Re: carb swap help
suggestions then? would like to go to a demon or quick fuel..
does the idle mixture even need to be plugged in?
i have unplugged it in the past (mistakenly) and the car ran the exact same
Old Mar 15, 2014 | 08:52 PM
makaveli09's Avatar
Engine: 350sbc
Transmission: TH700R4
Re: carb swap help
That is not a CCC Q-jet.its a dual capacity pump carb.
midge54
Dec 27, 2019 04:14 PM
theshackle
Mar 5, 2017 06:37 PM
midge54
Jan 29, 2017 07:00 PM
theurge
Aug 21, 2015 12:46 PM
cstrobel65
Aug 15, 2015 10:19 AM
