desprate need of help
Old Jun 25, 2014 | 03:06 PM
  #101
jwfirebird's Avatar
Car: 87 bird
Engine: enough to break stuff
Transmission: manual th400
Axle/Gears: 4.10
Re: desprate need of help
coolant is mixing with the coolant somewhere sounds like hard to tell where until you inspect the intake manifold gaskets. not much more work to do the heads. if the exhaust bolts come loose. whole gasket set for sbc isnt that much last time i bought one
Old Jun 25, 2014 | 04:06 PM
  #102
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
how about checking the pcv valve first? that's what I would do
Old Jun 26, 2014 | 11:39 AM
  #103
miguelc561's Avatar
I just did. Its fine. Im having a test done currently
Old Jun 26, 2014 | 12:28 PM
  #104
miguelc561's Avatar
I noticed a small amount of white smoke at start up and smelled like.antifreeze. Hopefully my motor wont go kaput
Old Jun 26, 2014 | 03:15 PM
  #105
miguelc561's Avatar
A compressiom test reveals a blown head gasket
Old Jun 30, 2014 | 03:02 PM
  #106
jwfirebird's Avatar
Car: 87 bird
Axle/Gears: 4.10
if you gaskets before the coolant mixes with the oil too long it will be fine. if it has the main bearings go south pretty quick
Old Jul 25, 2014 | 01:55 AM
  #107
miguelc561's Avatar
any ideas. This is warm when its cold it wont budge from 2000 rpms
Old Jul 31, 2014 | 07:57 AM
  #108
1982Z28Modified's Avatar
Car: 1982 Z28
Engine: 5.0L
Axle/Gears: Ten Bolt Disc Posi 3.23
Well Miguel, I just read your thread. A blown head gasket is very fixable. Don't give up on it yet. Just be careful how you spend your cash. The third gen is very fun to drive when it runs right. Myself I had to remove the computer, egr, air pump, cat, and change to a Holley 4175 and MSD vac/mech advance distributor to make it fun to drive.
Old Aug 1, 2014 | 03:18 PM
  #109
miguelc561's Avatar
That might have to be my route. But what do i do with that cluster of hoses that the o2 from the cat goes to that goes along the exhaust up into the motor bat
Old Aug 5, 2014 | 06:44 PM
  #110
miguelc561's Avatar
Just so you guys know ill selling my car for 800 dollars. I hate that car now. I took it to a shop that worked on it everyday for 2 weeks. I hungout and watched since ive had my fair share with it and they didnt even charge me cause they felt bad. Noone has a clue why it runs how it does. Ill have to go carless for awhile and this definetly ruined how i look at thirdgens
Old Aug 5, 2014 | 06:53 PM
  #111
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Yea 30ish year old cars are not for people who dont like to wrench.
Old Aug 6, 2014 | 08:43 AM
  #112
Car: 1982 Z28
Engine: 5.0L
Sorry to hear that Miguel. If you lived close to Michigan, I would buy it.
Old Aug 6, 2014 | 08:53 AM
  #113
jwfirebird's Avatar
Car: 87 bird
Axle/Gears: 4.10
i would agree with getting rid of all the emissions garbage and blocking the holes. there is way to much old stuff going in there to effectively trouble shoot. i had a 86 305 that was my first non stock swap on my v6 car and it was so much easier to work on when you can actually see the engine. its a good way to learn how to work on cars too. there are a ton on here that have done it for the same reasons.
89 Trans am
Exterior Parts Wanted
Oct 27, 2011 09:48 AM
blue birdy 87
Car Audio
May 26, 2011 08:49 PM
fakhro
Aug 15, 2010 01:31 PM
dsw12387
33
Sep 6, 2007 01:41 PM
