recommended Fuel pump/s
Old Jun 21, 2014 | 10:49 AM
X_Demonite_X's Avatar
Car: 06 impala 87 iroc z-28
Engine: 350 5.7 TPI
Axle/Gears: Pontiac WS6
Hello every one i was just wonder what the best fuel pump would be for a 1987 5.7 camaro i have alot of work to do with it so far i guess the car has been sitting for 8 years so i will probably start working with the tank fuel lines.
It is also TPI
Old Jun 21, 2014 | 10:50 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Re: recommended Fuel pump/s
I use racetronix stuff.
Old Jun 21, 2014 | 10:53 AM
Engine: 350 5.7 TPI
Thank you so much
Old Jun 21, 2014 | 11:36 AM
Ghettobird52's Avatar
Car: 88 Firebird Formula
Engine: LO5 5.7 TBI/Ebl Flash
Axle/Gears: 2.73 stock rear end
If this is a TPI car (like you stated) you can easily go with a OE replacement like this one here
Amazon.com: ACDelco EP241 Electric Fuel Pump: Automotive Amazon.com: ACDelco EP241 Electric Fuel Pump: Automotive
. This is what i just recently bought for my TBI but its easy plug n play swap for us. This is the correct replacement pump for TPI motors. IF you have tons of power under your hood you probably want to look at something bigger like a walbro
Old Jun 25, 2014 | 08:08 AM
rusty vango's Avatar
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
It is also TPI
I use NAPA parts. I got the best fuel pump they had to offer, that was almost 6 years ago. no problems
Old Jun 25, 2014 | 08:28 AM
taonindo's Avatar
Car: 82 firebird
Engine: 406
i had a walbro on my n/a noncomputer eng. but after 20 years it failed. (20 years is conservative) replaced it with a holly red. can only hope it last half as long.
Glowsock
Jul 24, 2025 03:15 PM
nhra-trans-am
Southern California Area
Sep 17, 2015 10:16 PM
gta90
Sep 15, 2015 04:00 PM
MustangBeater20
Carburetors
Aug 21, 2015 02:42 PM
92camaroJoe
Aug 13, 2015 06:07 AM
