TPI to carb mechanical fuel pump issue
Old Jul 8, 2014 | 10:14 AM
IroczFan's Avatar
Car: 86 IROC-Z
Engine: 383 Stroker Vortec
Transmission: 700r4 Built
Axle/Gears: 3:42
so I swapped from Tpi to carb I am using a mechanical fuel pump and trying to pull threw the stock Tpi lines, the car will loose fuel pressure and die within 2 miles and even at idle for along time, can it not keep up scince its pulling threw the Tpi pump?
Posted from Thirdgen.org App for Android
Old Jul 8, 2014 | 12:08 PM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Engine: Rebuilt 350 going in after paint
Transmission: WCT5, 7k & counting behind the 350
Axle/Gears: 4thgen disc rear w/ 3.73 Posi
Re: TPI to carb mechanical fuel pump issue
Most likely, yes. You'll need to drop the tank and install a carb fuel pickup.
Old Jul 8, 2014 | 03:14 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Go get yourself a nice thick frozen custard. Now, instead of a straw or spoon, use a coffee stir stick to suck it up.
That's what you're asking your mechanical fuel pump to do.
Either use the in-tank electric as a pusher pump to the mechanical (but only if your mechanical has a return); power the in-tank electric and install a return-style fuel pressure regulator (you can also put a return-style reg after the mechanical pump if your mechanical doesn't have a return); or drop the tank and remove the in-tank electric pump - there's a sticky in the top section of this forum called "Carb gas tank pickup" that explains how to remove the pump and convert the pickup to mechanical style.
Frozer!!!
Jan 19, 2024 04:55 PM
RazorN8
Jan 7, 2022 11:44 AM
theshackle
Mar 5, 2017 06:37 PM
beachrodder
Aug 25, 2015 08:05 AM
R3500
Aug 17, 2015 12:16 PM
