2.8 chevy camaro carb
Old Sep 23, 2014 | 09:47 AM
rusty vango's Avatar
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
so, a 82 Camaro was brought to me with issues. it will run great one time .and the next time you start it. it wont idle. turning the mixture screw does nothing. I can run it all the way in ,no change. I did a full tune up and all that .removed the carb (its a re-man)and it looks ok inside and out. still wont hold a idle. no vac leaks. what gives? thinking about milling a adaptor so I can mount another type of carb. but I really rather fix this one. help!!! by the way its a 2.8 v-6 with one of those 2se carbs. anyone have any adjustment advice?
Old Sep 23, 2014 | 11:41 AM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Re: 2.8 chevy camaro carb
I played with one of those setups on a 1985 S10 with a 3.1 swapped into it long enough to discover it was a big POS and never was going to run right. The carb gasket was crumbling and it had a ceramic grid efe heater in it. $150.00 for a gasket...YEA RIGHT!!! Pulled the carb setup off the truck and tossed on a TBI setup from a 1987 2.8 S10 on it. It ran a little lean so I tossed in some 4.3 injectors and cheated on the base timing about 4*. Driveability was so much better, turn the key and it would start and idle on a 20*F morning. Instant throttle response even when it was cold. I swear the thing gained 30-40 ft/lbs of torque down low and through the midrange. The little 3.4 truck actually ran about as well as a stock 4.3 TBI. It ran so well it smoked the transmission and had to have a rebuild. We later converted that truck to a camaro 4L60E, a 93-95 4.3 TBI ecm, and used an electronic speedometer setup. Removed the distributor and used the 3.4 DIS coil pack in it as well.
Old Sep 24, 2014 | 05:23 PM
Car: 86 IROC
Engine: 5.0 TPI
success!!! after rebuilding the carb and making sure all the internal specs were right. and fixing 20,000 vaccum leaks ,and doing a complete tune up, it runs right , and another happy customer is added to my roster.
Old Sep 24, 2014 | 06:27 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Glad you figured it out! I would have set fire to it!
Old Sep 24, 2014 | 06:40 PM
Car: 86 IROC
Engine: 5.0 TPI
cant burn up a customers car!! but yeah it WAS hell.isnt it funny when you put things back the way the factory had them , it just works?? most of whats brought to me is "billy did this and that ,now it wont idle" sorta stuff. a puzzle for a old man. but the grins on their faces and the " dayum, howd you do that!!??" only brings me more of their friends with their own #$%$#&^ car wont run right!! can you fix it?? so its all good, it keeps me buisy, and I really don't like idle time, so . bring on the projects!!
Frozer!!!
Jan 19, 2024 04:55 PM
midge54
Dec 27, 2019 04:14 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
Reborn756
Sep 4, 2015 03:42 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
