NEED HELP!!! z28 keeps stalling...
Old Sep 28, 2014 | 01:43 PM
Freekickerz's Avatar
Car: 84' Z28 camaro
Car was driving fine. came to a stop sign, stopped and the car shut off. the choke and check engine light came on. started up again. went a half mile down the road and the car seemed like it didn't want to give any power when i pushed on the gas. then the car stalled again. this time it doesn't wanna start. but when i try to start it again tiny puffs of smoke came up by the distributor cap but only when i turn the key. maybe the ignition module? but when i let it sit and it starts but doesn't want to stay on. Carburetor is old gonna have to fix that anyways. but then i was also thinking it might be the fuel pump? car has a new battery and the alternator is fine cause all the lights work. Need Help!!! btw the car is a Clean 84 Z28 camaro.
Old Sep 29, 2014 | 09:11 PM
Car: 84' Z28 camaro
Re: NEED HELP!!! z28 keeps stalling...
Never mind found out it is my carb. So cleaning that out and rebuilding it...
Old Feb 25, 2015 | 09:52 PM
Chris Kinn's Avatar
I'm having pretty much the same story except mine can't be the carb cause i have a 91 z28 with the TPI. I fried the previous MSD ignition box that I had while charging a capacitor off my battery. I replaced it with the stock ignition and ever since, I have been experiencing smoke coming from near the distributor and out of the exhaust. The car will only start sometimes. It cranks fer days but just wont spark sometimes. I have to hold the throttle down all the way just to get it to start (if it does). I replaced the stock ignition with a new MSD 6AL Box and the same stuff is happening. HELP. I think it may be something with the distributor.
starliner
Feb 9, 2016 08:18 PM
blackz281le
Jan 11, 2016 07:51 AM
David Frans
Oct 31, 2015 08:12 PM
Night rider327
Oct 9, 2015 09:25 AM
z28joe2
Sep 28, 2015 05:54 PM
