Fuel pump outlet fitting
Old Mar 12, 2015 | 06:45 PM
fteufert's Avatar
Car: 1982 T/A
Engine: 1973 400 Chevy
Transmission: 4 Speed Borg Warner
Axle/Gears: 3:23
Can I use this on a 400 SB, which has a Carter M6626 pump? The fuel pump outlet is quite close to my radiator hose.
Its from Mcmaster-carr,
Supported 45 Degree Brass Flared Tube Fitting, 90 Degree Elbow for 3/8" Tube OD x 3/8 NPTF Male, part number 6432T129.
What I would prefer is the same thing in a 45 degree fitting, or maybe a few suggestions.
Old Mar 13, 2015 | 01:08 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Fuel pump outlet fitting
I used an Edelmann 251660—Transmission Oil Line Coolant Adapter - 3/8 Inch Tube Size x 3/8 Inch (5/8-18) Male Inverted Flare x 4 1/2 Inch Length. I bent it to 90 degrees, but you could, of course, bend one to whatever angle you desire. I purchased at O'Reilly's.
JamesC
Attached Thumbnails Fuel pump outlet fitting-screen-shot-2015-03
Old Mar 13, 2015 | 10:51 AM
Night rider327's Avatar
Car: 1988 Camaro
Go to your local parts store like auto zone and ask to look through the fittings and adapters. The keep them in about a chest high metal shelf with pull out slide drawers, behind the counter and off to the side.
You will find the 90* like you pictured and a 45* like you want
Frozer!!!
Jan 19, 2024 04:55 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
