Vortec TPi to Carb TV Cable Question
Old Jun 29, 2015 | 11:23 AM
quick90rs's Avatar
Car: 1990 Camaro RS
Engine: 350 Vortec Demon 650CFM
Axle/Gears: Posi
Hey all, I've spent the day doing some research on here and figured I would start a thread to ask some questions. I am soon to be converting my 350 Vortec TPI to carb using the Weiand Vortec Intake and Summit 600 carb. (http://www.summitracing.com/parts/su...00vs/overview/).
I seem to understand that I will need either a TBI or Carb TV cable. My questions is in how the bracket will work for the new cable. I've seen many people recommend many brackets but there always seems to be some issue. I like the kit from bowtie overdrives, however that is $150 and if I could go a cheaper route I will. Any suggestions or reccomendations? Also, will I be all set with my throttle cable? or will I need a shorter one too?
Thanks in advance as always guys!
Old Jun 29, 2015 | 02:38 PM
MSgt Luttrell's Avatar
Car: 1986 IROC Z28
Engine: Carburated small block 454
Transmission: Level 3 Raptor 700R4 2600 stall
Axle/Gears: Strange S60 3:73 S Trac Posi
Re: Vortec TPi to Carb TV Cable Question
Here is a pic of the linkage and bracket set up you will need, several companies out there sell linkages and brackets for what you need, I got mine through Holley. Here is a pic of my set up........
Here is the bracket you need.........
http://www.summitracing.com/parts/hl.../applications/
Here is the linkage you will need with that carburator............
http://www.summitracing.com/parts/hly-20-121/overview/
Old Jun 29, 2015 | 11:07 PM
quick90rs's Avatar
Car: 1990 Camaro RS
Axle/Gears: Posi
Awesome thanks for the reply with pics. I should have no problem using these on the summit brand carb I assume? Also is there a preferred TV cable to use (carb or tbi) or are they the same
Old Jun 30, 2015 | 12:09 AM
Night rider327's Avatar
Car: 1988 Camaro
The summit carb is just an old holley design
Old Jun 30, 2015 | 08:45 AM
Car: 1986 IROC Z28
To my knowledge the two TV Cables are the same, except for legnth, where as the TBI cable is a little longer. Can anyone in here verify this for us?
Old Jun 30, 2015 | 04:54 PM
pancherj's Avatar
Car: 1990 IROC
Engine: Rebuilt L98 with H/C/I/Carb
Transmission: TH350 with ATI Treemaster
Axle/Gears: 7.5 with 4.10's
Avoid the Holley bracket...they bend way too easily. I used the CSR bracket with stock TPI cables. You need to trim the TV cable plastic that snaps into the Th350 kick down bracket that comes with the CSR bracket. I also had to slot the holes in the CSR bracket a little to get correct tension on the throttle cable.
Lastly, get the geometry corrector bracket that bolts to the Holley and provides the correct sweep for the TV cable. I used the TCI corrector.
Frozer!!!
Jan 19, 2024 04:55 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
redmaroz
Aug 16, 2015 11:40 PM
Sanjay
Aug 12, 2015 03:41 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
