86 z28 carb issue simple fix ?
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
Re: 86 z28 carb issue simple fix ?
Might be time for a cab rebuild. No fuel squirt could be an aging booster pump.
Change the filter first and see if there is a change. Use a 1" wrench on the big nut to keep from twisting the line.
Post back and we can help.
Thanks for the help.
Im leaning towards just rebuilding it and not have to worry for awhile.I like to have a quick fix just to have fun with the car alittle before winter.
Car: 1988 Camaro
If your interested I have a stock elec. Q jet off of a LG4 for sale. $115 shipped. It was on a running engine when I pulled it off a couple of mo. ago.
http://atlanta.craigslist.org/wat/pts/5094297715.html
https://www.thirdgen.org/forums/carb...-ccc-qjet.html
Aside from the above check your throttle shaft for play. It should be fairly tight with little noticeable movement back and forth (with throttle open). Bushing it is fairly simple.
theshackle
Sep 17, 2020 08:26 AM
theshackle
Mar 5, 2017 06:37 PM
86IROC112
Aug 17, 2015 02:00 PM
GVMV
Aug 16, 2015 08:01 PM
