No idle when warm
Car: 1988 Firebird
No idle when warm
I just finished at tbi to carb swap. Yesterday, which would be day 3 of driving my 305 auto firebird with non cc quadrajet and he I, car would cut out at highway speeds. I found out was not getting enough fuel as I was letting my mechanical pump pull through the in tank electric pump. Worked fine the first two days, then day 3 it didn't want to do it anymore. I got rid of the electric pump and fixed that problem. Now a contestant problem I have been having since day one is when car is fully warmed up, after driving say,20 mins, at stops while in gear car will not idle, I have to go to neutral to stay alive. Even if I try adjusting idle screw on driver side, it will raise idle but it had erratic idle and sounds like its missing or something. This only happens when warm, when cold it idles fine no erratic idling or anything. But when it's warm and can't idle, soon as I get on the gas, car drives fine, no hesitation no missing or anything. Just at idle. I sprayed carb cleaner all over base of carb and it didn't sound like there was a leak. What else do I look for
Transmission: 4L80E/4L80E
Meaning an older version with vacuum and mechanical advance, or the original TBI distributor?
Car: 1988 Firebird
Car: 1988 Firebird
Re: No idle when warm
Ok so now I really have to get this figured out as I let someone borrow my daily driver blazer and a drunk driver rear ended her and totaled my truck :/ thank god no one was badly hurt but my trucks frame looks like it twisted. so now the firebird is on permanent daily driver status, just need to get this idle issue figured out BC it gets annoying going to neutral every stop
Car: 1988 Firebird
I found 2 burnt plug wires that I didn't route correctly just laying on top of my manifolds so I temporarily got them off the manifold and electric taped the burn spots for the time being. Have to wait on my next pay check before I can get some new plug wires. Hopefully that's my problem
