Thought I had my cold start issues solved
Old Dec 10, 2015 | 09:05 PM
bubbaz28's Avatar
Car: 1983 Z-28
Engine: 305 LG4
Transmission: 5-speed
After reading many posts and trying to find out why my '83 Z28 with 4bbl qq jet runs so bad when the engine is cold... I saw one of Sonix's threads saying it was probably the choke... so I adjusted the leaf spring screw in a few turns and YES!! Started right up and didn't die like usual! All good, right?
Well, she seemed to run ok, but was idling around 1500-2000, and would not "kick down" too easily, but eventually did, at which time idle went to 500-750 and was rough.
So like an idiot, I fooled around with the screw again, turning it out 2 turns.Then it started, and idle kicked down quickly, to 500 rpm... ran real rough though, and died. After further "screwing" with the screw, now won't start at all! Crap! I will try again tomorrow night when I have a fresh {cold} start. Any pointers or advice?
BTW, thanks Sonix, your posts on choke stuff helped a lot! I may figure this out yet!
I believe I also have to set the dwell and timing- I will do those next...
Old Dec 11, 2015 | 08:31 PM
bubbaz28's Avatar
Car: 1983 Z-28
Engine: 305 LG4
Re: Thought I had my cold start issues solved
UPDATE_
So I tweaked it. starts immediately, and idles at around 2500-3000.
After about 3 mins., check engine light comes on. I gotta figure that one out...
A few minutes later, I hit the throttle and it kicked down.. to around 750-1000, and runs rough.
Upon restart, it starts right up but idles low and rough...
lt1z350
Wheels and Tires
32
Dec 1, 2015 03:19 PM
321FormulaGuy
Nov 13, 2015 06:10 PM
David Fite
Nov 13, 2015 12:29 PM
ndndndnd
Nov 13, 2015 07:36 AM
