Wanting to switch from edelbrock 2701 to spread bore intake
Car: 1984 Z28
Engine: LG4 305/4bbl for now
Transmission: 5-Speed
Axle/Gears: 3.23 Posi
I am looking to switch back to a non CC Q-jet on my 84 to get a factory looking set up and so my HO dual snorkel air cleaner set up fits correctly. My question is what is a good intake to switch to that will accept my Q-jet "spread bore" carb and not lose performance.
Car: 1987 Z28 Camaro
Engine: 305 LG4 4bbl
Transmission: TH700R4
Re: Wanting to switch from edelbrock 2701 to spread bore intake
Edelbrock performer non EGR with a spreadbore pattern would be my pick
Car: '86 Camaro, '94 Camaro, 3 others
Engine: LG4 ->L29, L32->LR4, L36, LG4, L31
Transmission: 700R-4, T5WC, 4L80E, SM465, 4L60E
Axle/Gears: 3.42, 3.23, WTB/WTT 2.93
I'm running the 3701, the Performer EGR, and it doesn't have the neat waffle pattern under the carb. If you want to change intakes, this is the one for keeping EGR, but if you don't need EGR, I'd encourage finding something with some sort of waffle texture under the carb. That is the only reason the EPS makes the extra torque over the Performer.
The only other EGR intake still available new is the GMPP one that came on the ZZ4. It's the exact same casting as the 3701, except with a bowtie in place of the Edelbrock name. I've had one. Guess who casted the GM version? Yep, Edelbrock. I just go with whichever one is cheaper.
Car: 1984 Z28
https://www.summitracing.com/parts/s...make/chevrolet. I ordered this one, it is shorter than the 2701 and has the waffle pattern in the plenum and for the price you cant beat it! thank yall for the help
