e4mc idle issues please help!
Old Mar 31, 2017 | 03:35 PM
84BrownBird's Avatar
Car: 1984 Trans Am
Engine: Lg4 305
hey guys ive got a 1984 trans am lg4 that ive been having idle issues with so I rebuilt the carb to no real effect (fixed several issues inside the carb but did not effect the idle) anyway the idle is erratic between 1000 and 1500 if I attempt to set it below a grand it just dies its throwing code 13 for 02 sensor and running really lean I know this because when I manually close the choke with my hand it revs and its also throwing code 44 (lean condition) I wouldn't think an 02 sensor could cause all of this
so any ideas yalls help will be greatly appreciated
Old Apr 2, 2017 | 09:16 AM
Car: 1984 Trans Am
Engine: Lg4 305
Re: e4mc idle issues please help!
anyone?
Old Apr 2, 2017 | 09:43 AM
Sounds like a fuel delivery problem... especially if it runs poorly when driving, and won't sustain full power output (or even anywhere close) for more than a few seconds.
Did you replace the fuel filter? How much fuel is in the bowl?
Incidentally, that carb's model # should be E4ME (electric choke), not E4MC. Don't know that there ever was such a thing as E4MC.
Old Apr 2, 2017 | 09:41 PM
Car: 1984 Trans Am
Engine: Lg4 305
pump and fliter are new i think its a vacuum leak ive just got to find it
Old Apr 11, 2017 | 08:56 AM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
My 84 had a very similar issue and it was fuel pressure as Sofa mentioned
If fuel pressure is good and filter is replaced, then I would lean toward Vacuum leak or floats set wrong.
