Stalls when slowing with clutch pressed
Old Jul 16, 2017 | 03:07 PM
kitt462d's Avatar
Car: 1985 TA
Engine: 350 Carb
I have a 350 with an Edelbrock carb installed and a T56. I just added a vacuum advance dist. and it runs almost perfect. Except when you press the clutch in while slowing down it stalls. When ideling at start up its aroud 1000rpm. kept electric fuel pump to a regulator. Any help is very appreciated. Thanks
Old Jul 17, 2017 | 01:30 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Re: Stalls when slowing with clutch pressed
Which port did you connect to the vacuum advance?
Where do you have your timing set? (I assume you set it with vacuum advance disconnected)
Old Jul 17, 2017 | 10:27 PM
kitt462d's Avatar
Car: 1985 TA
Engine: 350 Carb
I connected it to the passenger side of the carb. The timing is a slight mystery right now. I dont have access to a timing gun until next weekend and I just got it close enough to sound good for right now.
Old Jul 18, 2017 | 07:10 AM
dahuntin's Avatar
Car: 89 Camaro
Engine: 385
Transmission: '94 T-56
Axle/Gears: Broken 10 Bolt
Are you talking about hard braking or just slowing at a normal rate?
