Help with Fuel pump.
Old Jul 28, 2017 | 01:11 PM
Will Morse's Avatar
So I Have an 87 305 carbureted Vin Code H. It has the stupid 2 fuel pump set up. I have replaced the in tank fuel pump twice. This last time it only lasted for 2 days. What is the best option for me at this point. Should I remove the in tank pump and only use the mechanical pump on the block and an older fuel pick up. Or should I bypass the mechanical pump and use a more powerful in tank pump with regulator. The car is rust free, no leaks and only has 40,000 miles. I'm trying to make it a reliable daily driver.
Old Jul 28, 2017 | 04:26 PM
RocketyMan's Avatar
Car: '96 Camaro-Vsux -- SOLD, '84 Z/28
Engine: 3.8L, 305 SBC
Transmission: 4L60E, T-5
Axle/Gears: 3.08s, 3.23s
Re: Help with Fuel pump.
How are you going through pusher pumps so often?? Are you just buying cheap crap ones??
You could do away with the pusher pump and just run your mechanical one I'd imagine.
Old Jul 28, 2017 | 07:17 PM
NoEmissions84TA's Avatar
I would imagine dropping the tank to replace that fuel pump is a nightmare.
My vote is to abandon the in-tank pump and install a Carter M6626 mechanical on the block for reliability and ease of maintenance.
Old Jul 29, 2017 | 09:47 AM
RocketyMan's Avatar
I agree. On mine, I just have the mechanical pump. It does okay, but if you let your car sit for a while and your bowl gets empty in your carb, it will take quite a while to get fuel sometimes. Not too bad tho.
