Car stalls when in gear
Hello all,
i've spent all weekend on this 83 v6 carb and i'm out of ideas.
The car will idle just fine but if you press the gas or if you put it into gear it will almost certainly stall out and die.
If you goose the s**t out of it you can sometimes coax it enough to keep it running and if you can get it moving you can usually keep it going but if you drop into 1st gear speeds you have to be very careful and play a careful balance of more gas and less clutch to keep it running.
I have no lights on the dash, and I've already replaced the fuel filter, and changed the oil..etc. I've also cleaned the carb best i can with cleaner.
has anyone ever seen this before at all and could point me in any other direction?
Re: Car stalls when in gear
Oh I forgot to add that when you do goose it the car will obviously surge forward all at once, so it's not a very safe thing to do. I basically have to haul *** outta the neighborhood just to keep it running.
