84 HO car to Holley Sniper
Old Sep 5, 2017 | 10:09 PM
Craig84Z's Avatar
Car: 1984 Camaro Z28
Engine: Blueprint 383
All,
Got rid of the quadrajet years ago and now using a Holley 750dp. Thinking my next project will be an upgrade to Holley Sniper EFI system.
Can I use my current gas tank or should I upgrade to a 85-92 FI tank?
I like my Holley but just want to get something that will always be at optimum performance and not have to worry about changing jet sizes, power valve, float level, etc.
Would be nice to see a How To section for the third gen cars that are carbureted and go to the Holley Sniper EFI. Someone on here has had to do it. Maybe I just missed it? Seems all the posts are FI to carb.
Any other tips from someone that has done this upgrade?
Old Sep 6, 2017 | 08:16 AM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
Re: 84 HO car to Holley Sniper
I am thinking of going with Holleys Sniper efi also. There are a few on here that did the FiTech swap. Summit Racing just came out with their own self learning efi Max-500 I think is the name. We now have several different options on the market. Atomic EFI to name another.
I plan on doing a intank pump which will not be as noisy as the external pumps.
Old Sep 6, 2017 | 02:09 PM
Craig84Z's Avatar
Just wondering if I need a later year FI gas tank or okay to use my 84 tank?
Old Sep 6, 2017 | 02:39 PM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
You will have to run a return line and modify the stock tank unless you use FiTech's fuel command center system.
Old Jun 19, 2018 | 06:15 AM
bluehog's Avatar
Car: 84 MSE TransAm #22
Engine: SBC 350 +.060, Holley Sniper EFI
Transmission: 1991 T5 WC
Axle/Gears: Eaton TrueTrac in Dana44 case- 3.31
Craig84Z - did you ever make the switch to the Sniper? Would love to hear your review as I am planning this in the coming months.
Old Jun 19, 2018 | 07:46 AM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
anyone that may still be interested can use their existing carb tank and lines-provided your vehicle has the in-tank helper pump (most HOs and later LG4s). just need to drop the tank and install a higher pressure pump. If you have a tank without a pump you can swap in the FI fuel sender.
Some re-working of the fuel lines in the engine bay will need to be done to connect to the FI unit.
Old Jun 20, 2018 | 09:17 PM
Craig84Z's Avatar
Blue hog- unfortunately I haven’t been able to make the switch yet. Post up here if you get to do before I do😊
