What's bellow my throddle cable?
Old Oct 9, 2018 | 04:31 AM
ChelseaHere's Avatar
Car: 86 Camaro Sports Coupe
Engine: 383 Stoker
Transmission: 700R4 transmission
Hi.
I'm not sure what this cable below my throddle cable is. In my pictures, it looks to be clipped. What is this cable? Is it meant to be cut? If it's not meant to be cut, what should i do?
Thanks!
Cut cord
Old Oct 9, 2018 | 07:35 AM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
Re: What's bellow my throddle cable?
http://www.tvmadeez.com/
Old Oct 9, 2018 | 10:31 AM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
That looks like the TV cable for the 700R4 transmission
Old Oct 9, 2018 | 12:01 PM
jstadmud's Avatar
Car: 1987 IROC Z28
Engine: 5.0 liter
Transmission: 700R-4
Axle/Gears: 273 posi trac
Click the video link above to see the small bracket needed to make your transmission cable function properly with the 700r4 transmission in your car. Very important for this cable to be hooked up and adjusted properly, very inexpensive but very crucial for proper transmission functionality.
Your cable is not cut, the black plastic piece clips onto the bracket in the video, and picture below.
Old Oct 9, 2018 | 02:58 PM
Engine: 383 Stoker
Originally Posted by jstadmud
https://youtu.be/6VVxHhe0oeo
Thank you so much! I'll be sure to get that item! I'm hoping this will do the trick!
Old Oct 9, 2018 | 05:29 PM
GeneralDisorder's Avatar
DO NOT drive the car with that disconnected. It will ruin the transmission.
GD
Old Oct 9, 2018 | 05:49 PM
Engine: 383 Stoker
GD
I'll leave it turned off for awhile. I'll try buying that piece asap! Thank you everyone!
1EasyRider
Nov 4, 2003 05:06 PM
aziroc
Jul 27, 2001 11:15 AM
