E4ME Electronic quadrajet question.
Old Nov 2, 2018 | 10:26 PM
'83Daytona's Avatar
Car: 1983 Pontiac Trans Am
Engine: 305 CI V8(LG4)
Transmission: T5 5-speed
Hello all, I am in search for replacing my car's stock quadrajet with a brand new/remanufactured unit because of age and vacuum leaks all over the body. I have recently modified my lg4 and am a bit stumped as to what to look for... the engine is breathing much easier (heads and cam have been upgraded) and i'm not sure if a stock re-manufactured E4ME quadrajet will suit the AFR requirements at wide open throttle. As of now, it sputters when the secondaries open due to fuel starvation. Heads are world S/R torquer 305's, 1.94'' intake valves and 1.5'' exhaust. 58cc combustion chambers and 170cc intake ports.
Cam specs:
Duration at 050 inch Lift: 210 int./216 exh.
Advertised Duration: 270 int./276 exh.
Valve Lift with Factory Rocker Arm Ratio: 0.440 int./0.454 exh.
Lobe Separation (degrees): 114
If there are any options out there for modifying the new q jet, or getting one from someone that modifies/tunes these (if needed), please let me know!
Best regards,
Zack.
Old Nov 2, 2018 | 10:50 PM
gt4373's Avatar
Transmission: 5-Speed Manual
Re: E4ME Electronic quadrajet question.
https://www.smicarburetor.com/
budowski
Carburetors
Apr 12, 2016 10:28 AM
Bull86
Carburetors
Jul 28, 2015 11:07 AM
jayson.ortiz
Carburetors
Feb 6, 2009 10:31 PM
Apeiron
Carburetors
Nov 7, 2007 11:27 AM
