carb help
Old Jan 11, 2002 | 07:04 PM
1986redbird's Avatar
carb help
hey guys,
I have a question about the CCC quads, I have rebuilt the carb using all of damon's suggestions except the rods and hangers. I have the tuning gauges for the carb and set the lean stop, the rich stop and the IAB valve to they're specs. not sure of the idle mixture screws though so went 4 turns out from bottom. I hooked up my dwell gauge to the lonely green connector near the fire wall next to the heater fan, the question is ??? the dwell gauge shows a steady 27* and nothing I do seems to make it waver at all, I tried the mixture screws and the IAB and nothing changes it. did I miss something or can there be another problem ????
Old Jan 15, 2002 | 10:46 AM
Damon's Avatar
The ECM will not start to adjust the M/C control soenoid until it goes into closed loop mode (the O2 heated up). Until then it sends a constant duty cycle signal to the carb.
Old Jan 15, 2002 | 01:12 PM
thanks Damon. I forgot to mention that the motor was already warmed up prior to trying the test, we had driven it about 25 miles just before. I have already replaced the 02 sensor when installing the new motor, the motor runs better than ever but I wanted to make sure everything was correct. I anyone has any ideas on this please respond !!!
thanks again.
Old Apr 15, 2003 | 08:11 AM
phess11's Avatar
Car: 83 Z28
Engine: 305 (LG4)
Transmission: THM700R4
Axle/Gears: 10 bolt, 3.23 non-LS
Hey Redbird, did you ever figure out what was the problem? Mine is doing the same thing.
thanks,
RedLeader289
May 28, 2019 01:47 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
IROC ZELLER
Sep 29, 2015 03:00 PM
efiguy
Sep 27, 2015 01:30 PM
