Carb
Old Apr 1, 2023 | 04:24 PM
thumperr6@gmail's Avatar
Carb
What causes a carb to pop every once in awhile. Sometimes when I gas on it but not all the time
Old Apr 1, 2023 | 04:43 PM
Re: Carb
I'm going to guess that this is when you give it more throttle. The more you give it, the more it tends to do it. ???
If it spits back through the intake, 99% of the time it's because it's lean. The other 1% it's because of a valve train problem.
Someone will come on and post something about "check your 'timing'". Typical n000b response. Ignore them.
bad_turbo
Aug 24, 2003 06:14 PM
jfox55
Carburetors
Feb 13, 2002 09:41 PM
