QuadraJet Rebuild Kits?
Old Jan 22, 2002 | 05:23 PM
Trevor K's Avatar
OK, I'm thinking of rebuilding my QuadraJet myself (And it does need it). Is there a place where I could get a kit that would include all necessary parts? How much would this cost?
Would I be better off just buying a new carb?
Old Jan 22, 2002 | 06:07 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
You should be able to get a kit from most any parts store. Take the carb number in when you go looking for it (located on the driver's side rear corner of the carb).
The kit will include gaskets, rubber parts like float needle (and seat) and small seals; stuff needed to take the carb apart, clean it, and put it back together. It will not include things like float, TPS, MCS, choke thermostat or pull-off - things that can go bad. Those things will cost you extra. But, unless ALL of them are bad, you aren't going to be better off cost-wise getting a complete rebuilt carb.
Old Jan 24, 2002 | 10:54 AM
Pony Killer's Avatar
Car: 1986 Z28
Engine: 355
Transmission: th400
the rebuild kits are under 30 bucks if i remember..
One thing.. get the float, and get the brass one.. the black plastic ones tend to leak, and the float fills with gas, and no longer floats.
for the lil extra money it's probalby a good idea to get the tps, and mcs.. but if you don't.. no biggie, they generally don't go bad too often.
One other tip, when you've got it cleaned up the bowl plugs tend to leak. take some nail polish, and coat them, they will never leak.
Old Jan 24, 2002 | 11:09 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Especially when he doesn't have either.
An M4ME rebuild kit should be about $70 from NAPA, Auto Value, or Part Source.
Old Jan 24, 2002 | 05:28 PM
five7kid's Avatar
Ah, yes, good ol' Canada...
Old Jan 24, 2002 | 07:25 PM
Car: 1986 Z28
Engine: 355
Transmission: th400
That is the truth.. lucky canadians.
it'll prolly take ya a little longer to rebuild the non ccc qjet then
Old Jan 25, 2002 | 10:14 PM
Trevor K's Avatar
So would this make my carb easier to rebuild then if I am non-computer-controlled?
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
1Aauto
Sponsored Vendors
Jan 15, 2016 06:26 AM
tonys91rs
Oct 10, 2015 03:31 PM
armybyrd
Carburetors
25
Sep 13, 2015 01:49 PM
1Aauto
Sponsored Vendors
Sep 10, 2015 02:02 PM
