Help needed
Old Jan 1, 2025 | 09:33 PM
Gscout72's Avatar
Help needed
Hi,
I recently installed an Edelbrock AVS2 8962 carburetor on my 1972 International Scout II with a V8 345 engine. I知 looking for recommendations on the type of fuel pump I値l need, as well as a compatible fuel regulator.
Any advice or suggestions would be greatly appreciated!
Thank you!
Old Jan 1, 2025 | 09:41 PM
T.L.'s Avatar
Car: '83 Firebird (T/A Clone)
Axle/Gears: 10-bolt/3.73 ..
Re: Help needed
I recommend a International Scout forum...
Old Jan 1, 2025 | 10:06 PM
Beeman's Avatar
Re: Help needed
Electric?? Holley blue or a Mallory electric with the compatible regulator should work fine.
Old Jan 1, 2025 | 10:30 PM
Gscout72's Avatar
Re: Help needed
Thank you- will do
Old Jan 7, 2025 | 10:31 PM
Berlinetta00's Avatar
Veteran: Marine Corp
Car: '84 Berlinetta
Engine: ZZ4
Transmission: BTOD stage 3
Axle/Gears: 3.23 posi disc
Re: Help needed
Agree that this is more of a Scout forum issue, but as I have one of those too...
I would avoid going with the Holley type of you have the dual tanks. The vane style pumps are designed to push fuel, not pull it much, and can burn out quickly if they have to pull fuel any distance. The passenger side tank on mine has a good distance before it gets to the tank selector valve then onward to the engine. I would be more inclined to stick with a mechanical pump, it will feed that 345 everything it needs without redesigning the fuel system.
34blazer
Aug 28, 2019 02:50 PM
IROCWPB
South East Region
Mar 25, 2011 03:29 PM
ajm_shorty
Mar 9, 2003 06:42 PM
