Timing question?
Old Feb 12, 2002 | 01:46 PM
Brian Felts's Avatar
Car: 89 RS 355/ 89 IROC Convert
Engine: Hot Cam 355/TPI 305
Transmission: All 700r4's
Timing question?
Hey got the TBI off and the Carb On (street Avenger 770) what would be a good base timing for my car.
Brian
Old Feb 12, 2002 | 04:38 PM
Jester's Avatar
You did change the distributer too...right?
Assuming you did the best way to set timing is by total and not base. Get a dial back light, timing tape, degreed balancer, degreed cover, etc. have a friend rev it up and set it by the most advanced point. 35 degrees is pretty typical to start with..all in by 3000 rpm, then you can tune it from there.
Usualy works out to somewhere in the mid teens base...but it will vary from one spring/wieght set to the next.
Old Feb 12, 2002 | 05:17 PM
Yes I used the proform HEI with MSD 6AL. I have it about 10* now and it just does not feel as strong as it did with the TBI.
Brian
MustangBeater20
Oct 29, 2022 09:20 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
