Carb jetting
Old Mar 4, 2002 | 12:35 AM
nagga's Avatar
Carb jetting
hi
i have a 84 z28 camaro, i built a motor and would like to know if you guys can help me on jetting before i put the carb on, this is what i have, btw the motor is a 350
flat top pistons not sure what compression, prolly like 9.5, crane cam, 222 duration, with .467 int/exh lift
Wieand Xcelorator intake, single plane open plenum, the carb is an Edelbrock Performer 750cfm, i am at sea level here in alaska, please help me with this, thanks in advance
Old Mar 5, 2002 | 02:55 PM
johnsjj2's Avatar
Car: 1991 Z-28
Transmission: T-5 (gonna buy the farm)
Where are you going to drive that in Alaska? I was born there about 24 years ago. Left when I was 3. Gorgeous in the summer time, all 3 weeks!!! LOL The best way to jet that carb is to put it on, and see how it runs. I would reccomend the stock setting. Reading the plugs is a good way to see what the carb is doing. This is the only way I have had luck dialing in a carb. I am still tinkering with mine.
Old Mar 5, 2002 | 08:03 PM
bradkeith's Avatar
nagga, I was just wondering about your engine combination. It seems odd to me to see a single plane intake with a cam with those specs? I have a new edelbrock 750 carb on my 327 and it runs great. I need to step up from the stock jets though because i'm running a little too lean.
RedLeader289
May 28, 2019 01:47 PM
efiguy
Sep 27, 2015 01:30 PM
Damon
Sep 26, 2015 04:29 PM
lanceflame44
Sep 25, 2015 12:28 PM
