Where is the part number on Holley's?
im not a holley guy but as far as i know its usually on the choke tower as you look at the carb from the front, youll see a number like 3310 on the upper left or right side i cant remember which but i think its right
Car: 2000 astro
Engine: 4.3
Transmission: A4
Axle/Gears: 7.5 with 3.42 gears
The choke tower is typically cast into the main body of the carburetor. A notable exception are the Dominator carbs made after 1983, as they come without this choke tower.
But anyway, back to the issue at hand.
On one side of the carb, you may see a fuel line running from float bowl to float bowl. This typically indicates a Holley carb with vacuum secondaries.
www.mortec.com has listings of list numbers for Holley carbs, and also, the Haynes manual for Holley carbs has many of the list numbers, plus all info needed to rebuild any Holley carb back to factory specs.
1992 Trans Am
May 10, 2023 07:19 PM
IrocZ'85
Aug 17, 2015 06:24 PM
